[gdal-dev] RE clip intersected
Fri Jul 17 16:25:25 EDT 2009
Steve.Toutant at inspq.qc.ca wrote:
> I finally got gdal_polygonize.py and tried it and generate a shapefile.
> I might not use it as a solution for what I described below but I would
> like to use it for other purpose.
> My understanding is this function merge contiguous cells with the same
> pixel value.
Steve,
That is correct.
> Can I use this function and specify a range of value?
> Example: merge contiguous cells having a value > 16 and < 19
No, it does not support any mechanism like that.  It is assumed the
user would do preprocessing to turn ranges into a mask.
Best regards,
