[gdal-dev] Converting raster pixel space to geospace
Smart, Gary Gary.Smart at Goodrich.com
Mon Jul 20 10:49:33 EDT 2009
Thanks Martin, but now to the next problem...
I downloaded PRROJ.4 which seemed to configure and compile OK.
Having set the PROJ_LIB as you proposed, I now get:
ERROR 1: No PROJ.4 translation for source SRS, coordinate transformation initialization has failed.
I guess I am still missing comething.  The failure came from the same geotiff file as below.
I also couldn't find a 'data dir' in the GDAL source and therefore GDAL_DATA env var remained unset.  We installed everything from the FWTools download for our Linux SUSE10 system.  Should there be a 'data' directory under the FWTools directory somewhere?  There is no GDAL source in this directory - just include files and libraries.  I presumed this was all that was needed to use GDAL?
From: Martin Chapman [mailto:chapmanm at pixia.com]
Sent: 20 July 2009 14:49
To: Smart, Gary; gdal-dev at lists.osgeo.org
Subject: RE: [gdal-dev] Converting raster pixel space to geospace
Gary,
Set your paths like such on startup or as an environment variable:
GDAL_DATA points at the data dir that comes with gdal source.
PROJ_LIB point to the nad directory that you download from proj4 website.
string env = string("GDAL_DATA=") + dataPath;
_putenv(env.c_str());
env = string("PROJ_LIB=") + nadPath;
and / or
CPLSetConfigOption("GDAL_DATA", dataPath.c_str());
CPLSetConfigOption("PROJ_LIB", nadPath.c_str());
Martin
From: gdal-dev-bounces at lists.osgeo.org [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Smart, Gary
Sent: Monday, July 20, 2009 7:38 AM
To: gdal-dev at lists.osgeo.org
OK - I can get it to compile and not crash instantly (bonanza!)
However, when I try to create the OGR transform using importFromWkt,
I get the following:
ERROR 6: Unable to load PROJ.4 library (libproj.so), creation of
OGRCoordinateTransformation failed.
Does anyone know what this means?  Is there some part of OGR/GDAL I have yet to install?
My input projection is:
GTiff/GeoTIFF Projection PROJCS["TM          D-01",GEOGCS["NAD27",DATUM["North_American_Datum_1927",SPHEROID["Clarke 1866",6378206.4,294.9786982139006,AUTHORITY["EPSG","7008"]],AUTHORITY["EPSG","6267"]],PRIMEM["Greenwich",0],UNIT["degree",0.0174532925199433],AUTHORITY["EPSG","4267"]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",-124.5],PARAMETER["scale_factor",1],PARAMETER["false_easting",0],PARAMETER["false_northing",0],UNIT["metre",1,AUTHORITY["EPSG","9001"]]]
...and I am looking to output WGS84 lat/longs.
> -----Original Message-----
> From: Even Rouault [mailto:even.rouault at mines-paris.org]
> Sent: 16 July 2009 19:44
> To: Smart, Gary
> Cc: gdal-dev at lists.osgeo.org
> Subject: Re: [gdal-dev] Converting raster pixel space to geospace
> Le Thursday 16 July 2009 10:41:02 Smart, Gary, vous avez écrit :
> > But how do I load a OGRSpatialRef object with the output from the
> > GDALApplyGeoTransform?  Presumably I can prime the OGRSpatialReference
> > using the result of GDALDataset::GetProjectionRef?
> Yes, almost. See below
> > I'm not yet sure of my
> > terminology but is the GetProjectionRef supposed to satisfy the OGR
> > importFromWkt (the types seem to clash though - char* vs char**)?
> Maybe the doc of OGRSpatialReference::importFromWkt() (see
> http://gdal.org/ogr/classOGRSpatialReference.html#b74cfc985bd05404a4c61d2d
> 633a6343)
> isn't clear enough ? I must confess that the prototype is a bit weird. You
> don't pass the string itself, but a pointer to a string. The pointer will
> be
> modified to point to the remaining (unused) input, what you generally
> don't
> care about.
> Ok, here's a sample snippet :
> OGRSpatialReferenceH hSRS = OSRNewSpatialReference(NULL);
> const char* pszWkt = GDALGetProjectionRef(hDS);
> OSRImportFromWkt(hSRS, (char**) pszWkt);
> (For the purists, a more correct prototype of importFromWkt () would have
> relied on 'const char**' to avoid the above cast)
> But a simpler approach would be just :
> OGRSpatialReferenceH hSRS;
> hSRS = OSRNewSpatialReference(pszWKT);
> which instanciates the OGRSpatialReferenceH object and call internally
> importFromWkt()
> > I suspect my output projection could then be set up with
> > SetWellKnownGeogCS("WGS84") in order to convert from whatever input
> > projection prevails, to a standard WGS84 lat/long representation (using
> >    OGRCreateCoordinateTransformation::Transform)?
> Yes. Actually, it will be long/lat in term of the order of the
> coordinates.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090720/73c39dcb/attachment-0001.html
