[Gdal-dev] GDAL and ECW
jteasis jdt113 at msstate.edu
Mon Jul 20 11:02:34 EDT 2009
I got the files but all I have is Extract.exe and a batch file. Is this
correct and is there a place I need to put them or do I need to put them in
a specific location? Thank you so much for the help. It is greatly
appreciated.
Daniele Romagnoli wrote:
> Hi,
> we have already done it for ImageIO-Ext (a Java project which uses GDAL).
> You can take a look on the Imageio-ext setup guide which is available at
> [1].
> It contains instructions to setup and build GDAL to support several
> external
> formats, as well as instructions to build the java project.
> You don't need to read all the guide but you could take a better look to
> the
> following sections:
> 2.7.1.3, 2.7.2.4 , 2.7.3 (Only the introduction, no need to proceed with
> 2.7.3.1).
> Hope this helps.
> Regards,
> Daniele
> [1]:
> https://imageio-ext.dev.java.net/files/documents/7505/124115/ImageioExt-SetupGuide.pdf
> On Mon, Jul 20, 2009 at 3:50 PM, jteasis <jdt113 at msstate.edu> wrote:
>> I looked at the gdal website about hooking up ECW with GDAL on windows
>> but
>> it
>> says it needs to be done. Who can do this and where do I get these
>> instructions?
>> Even Rouault wrote:
>> > Le Thursday 16 July 2009 18:08:33 jteasis, vous avez écrit :
>> >> I am working towards getting a program using ECW and other formats. I
>> >> have
>> >> gotten my GDAL 1.5.4 to install with the rest but ECW is giving me
>> >> problems. I was wondering if there was somebody who could help me
>> figure
>> >> out how to compile GDAL with ECW correctly. I would greatly appreciate
>> >> it.
>> >> Thank you.
>> > See http://trac.osgeo.org/gdal/wiki/BuildHints, section 'External
>> Library
>> > Issues'.
>> > You could also fetch precompiled binaries with ECW support. See
>> > http://trac.osgeo.org/gdal/wiki/DownloadingGdalBinaries (not all of
>> them
>> > have
>> > ECW support, but some yes)
>> > And note that the latest stable version is GDAL 1.6.1.
>> > _______________________________________________
>> > gdal-dev mailing list
>> > gdal-dev at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
>> View this message in context:
>> http://n2.nabble.com/GDAL-and-ECW-tp3268583p3288913.html
>> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> Eng. Daniele Romagnoli
> Software Engineer
> GeoSolutions S.A.S.
> Via Carignoni 51
> 55041 Camaiore (LU)
> Italy
> phone: +39 0584983027
> fax:     +39 0584983027
> mob:   +39 328 0559267
> http://www.geo-solutions.it
View this message in context: http://n2.nabble.com/GDAL-and-ECW-tp3268583p3289319.html
