[gdal-dev] Gdal_merge
Mon Jul 20 14:34:49 EDT 2009
Denis Rykov wrote:
> Hi!
> I need merge two images - the first image is mutiband and second image
> is singleband.
> Can I do this operation with gdal_merge or gdal_merge works only with
> images with same number of bands?
> What utility from gdal library I can use for separate multiband image
> into some singleband images?
Denis,
You can use gdal_translate to extract a subset of bands from an image.
The following would copy just band 2 from in.tif into a new file, out.tif.
   gdal_translate -b 2 in.tif out.tif
The following would take the first three bands from a 4 band input file.
   gdal_translate -b 1 -b 2 -b 3 rgba.tif rgb.tif
Best regards,
