[gdal-dev] Creating a new raster and adding data
Henneke, Amanda M amanda.m.henneke at boeing.com
Mon Jul 20 15:51:40 EDT 2009
Thanks Even!  Your suggestion worked, adding each band individually!!
Also, thanks for writing up that ticket, I'm glad to know I wasn't going crazy!!
Amanda M. Henneke
When One tugs at a single thing in Nature, he finds it attached to the rest of the world. -John Muir
  Please consider the environment before printing this e-mail.
-----Original Message-----
From: Even Rouault [mailto:even.rouault at mines-paris.org]
Sent: Monday, July 20, 2009 2:17 PM
To: gdal-dev at lists.osgeo.org
Cc: Henneke, Amanda M; Tamas Szekeres
Subject: Re: [gdal-dev] Creating a new raster and adding data
Amanda,
you're not doing anything wrong now. It's rather a defect of the current C# GDAL bindings when dealing with multiple bands. See ticket
http://trac.osgeo.org/gdal/ticket/3073 that contains a proposed fix for the issue.
In the meantime, you can use the WriteRaster() method on each band instead.
For most drivers, it will have similar performance to WriteRaster() on the dataset itself.
Best regards,
Even
Le Monday 20 July 2009 18:36:27 Henneke, Amanda M, vous avez écrit :
> Ok, so after some more experimentation, I think I found that the
> reason it was dying was due to a file being too large.  When I run it
> on a smaller dataset, it seems I am successful in getting past the
> WriteRaster command in my code.
> The bad news is that it doesn't seem to be working properly.  It seems
> to write the first band correctly, but bands 2-5 are written
> incorrectly.  The buffer I'm using checks out before and after the
> WriteRaster command.  So it has got to be something with the
> WriteRaster command that is not working.  I've played with the offsets and all,
> especially the bandspace, linespace and rasterspace arguments.   Anyone
> have similar problems, or any ideas as to why I can't get the
> WriteRaster to work?
> Thanks!
> Amanda M. Henneke
> From: Frank Warmerdam [mailto:warmerdam at pobox.com]
> Sent: Friday, July 17, 2009 3:33 PM
> To: Henneke, Amanda M
> Henneke, Amanda M wrote:
> > Thanks Frank for your help, I think I'm further, but still not quite
> > there.
> > The definition requires me to send the iBandMap as an array, I
> > cannot insert the index of the band I wish to write, because then
> > I'm just passing an integer.  So with that said, I decided to
> > combine all my byte arrays (buffers) of data into one array and call
> > Write Raster as
> > follows:
> > byte[] buffers = new byte[(iHeight * iWidth) * 3];
> > r_buffer.CopyTo(buffers, 0); g_buffer.CopyTo(buffers,
> > r_buffer.Length); b_buffer.CopyTo(buffers, r_buffer.Length * 2);
> > ds_new.WriteRaster(0, 0, iWidth, iHeight, buffers, iWidth, iHeight,
> > 3,
> > iBandMap, 0, 0, 0);
> > But I'm still getting the same exception, so something else must not
> > be quite right.  I've tried playing around with the pixelSpace,
> > lineSpace and bandSpace parameters and still no success...any other
> > ideas what I'm still missing?
> Amanda,
> Your new approach looks reasonable.  I don't know what is going wrong.
> Best regards,
