[gdal-dev] How do I open vector files (e.g. shp) using GDAL
Even Rouault even.rouault at mines-paris.org
Mon Jul 20 17:03:21 EDT 2009
Le Monday 20 July 2009 22:51:13 Smart, Gary, vous avez écrit :
> I understand that GDAL can open vector formats as if they were a
> dataset?
No, not exactly. GDAL is for the raster formats. OGR is for the vector
formats. They have each their concepts, API and notions. See the OGR
documentation : http://gdal.org/ogr/
> E.g. I read that it is possible to pass the GDALOpen either a single
> .shp file (in which case it treats it as if it only had one layer) or a
> directory containing multiple .shp files - which presumably it opens as
> multi layered?
> However, whenever I try to open vector files in this way (directory or
> file) I get...
> ERROR 4  - blah blah is not recognised as a supported file format"
> I am still new to all this (having only just conquered raster formats)
> so I suspect I am doing something pretty dumb.
> Perhaps someone can help?
> Gary
