[gdal-dev] Messages: gdal_translate and gdal_rasterize
Tue Jul 21 12:14:39 EDT 2009
Steve.Toutant at inspq.qc.ca wrote:
> Thanks Frank,
> ".... the command cannot determine it from the .shp file"
> Why? Is it because the EPSG code of this .shp is unknown to GDAL or GDAL
> can't get any SRS from a .shp?
> Should I add the EPSG code somewhere in a configuration file?
Steve,
Presumably it is because there is no .prj file with the .shp file.  This
is quite common.
Best regards,
