[gdal-dev] Reading ArcInfo binary grids with the R rgdalpackage fails with "GDAL Error 3: Attempt to read past EOF in..../arc.dir"
Jason Roberts jason.roberts at duke.edu
Wed Jul 22 13:14:40 EDT 2009
Thanks Matt, that is very interesting to know that the Python bindings fail
with the same problem. Which version of GDAL are you using with the Python
bindings?
> So it seems like either all bindings need to silently ignore this error
> or have it fixed in the GDAL source.
Even and other GDAL devs, can you advise us on this?
Thanks,
Jason
-----Original Message-----
From: Gregory, Matthew [mailto:matt.gregory at oregonstate.edu]
Sent: Wednesday, July 22, 2009 12:09 PM
To: Jason Roberts
Cc: gdal-dev
Subject: RE: [gdal-dev] Reading ArcInfo binary grids with the R rgdalpackage
Hi Jason,
Jason Roberts wrote:
> Markus - thanks for the links to those tickets. Those tickets
> seem to imply this is a minor annoyance. Unfortunately, for
> me, it means I can't read the grids at all from R. Perhaps if
> I was using the C interface there would be a workaround (just
> ignore the error?) but this is not possible using the R
> interface, as far as I can tell. For example, the rgdal
> GDAL.open API fails with the same message.
I was one of the people that wrote up a ticket on this.  Ironically, it
looks like it was a bug fix that Even implemented (rev. 16460) that
allowed the INFO directory to be read correctly (so that the VAT is
read), which exposed the source of these errors.
> Is the right solution to get the rgdal developers to code a
> workaround to ignore the error somehow? Or is it to determine
> the underlying problem in GDAL? Or perhaps ESRI is generating
> grids that violate the AIG format specification?
I hadn't worked with this outside of the C interface, but I'm noticing
now that the same problems crop up in the Python bindings:
  >>> from osgeo import gdal
  >>> ds = gdal.Open("D:/matt/vat_test/grid1")
  ERROR 3: Attempt to read past EOF in
D:/matt/vat_test/grid1/../info/../grid1/vat
  .adf.
  >>> type(ds)
  <type 'NoneType'>
or have it fixed in the GDAL source.  I'll admit that my understanding
of what really needs to happen is often shaky ...
matt
