[gdal-dev] Slovenia vector data reprojection issue
Markus Neteler neteler at osgeo.org
Fri Jul 24 10:31:59 EDT 2009
I am trying to reproject Slovenian country data from D48 (WKT attached)
and Italian ISTAT national vector data (UTM32/ED50) into a common
projection.
While the map "attach" rather well in Latlong/WGS84 using GDAL 1.6.svn,
they don't in EU LAEA (EPSG 3035). This is a bit suprising for me.
Any trick to get this done?
The input SHAPE files have each a .prj file (attached), the target SRS
I request by -t_srs epsg:4326 or -t_srs epsg:3035.
My preferred SRS would be EU LAEA to match the EU CORINE data.
thanks
Markus
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090724/f9276f82/epsgD48_3787.obj
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090724/f9276f82/eu_etrs89_laea.obj
