[gdal-dev] Precission problem with atof
Jorge Arévalo jorge.arevalo at gmail.com
Fri Jul 24 13:18:36 EDT 2009
2009/7/23 Mateusz Loskot <mateusz at loskot.net>:
>>> Jorge ArÄ&#65533;Ĺ valo wrote::
>>>> Hello,
>>>> Context: GDAL WKT Raster Driver
>>>> While creating the Dataset, I execute this query:
>>>> SELECT srid, ST_AsText(extent), pixelsize_x, pixelsize_y, blocksize_x,
>>>> blocksize_y FROM raster_columns WHERE r_table_name = 'table' AND
>>>> r_column = 'rast'
>>>> I have loaded a 3-band tiff file with gdal2tiles. Its pixel size is
>>>> 0.9. If I execute this line (over the result of the previous query):
>>>>  fPixelSizeX = atof(PQgetvalue(hPGresult, 0, 2));
>>>> I get 0.899999976158142 instead of 0.9.
>>> Good.
>>>> The string obtained wiht PQgetvalue is "0.9", but, for any reason,
>>>> atof transform this string in 0.899999976158142.
>>> http://docs.sun.com/source/806-3568/ncg_goldberg.html
>>>> So, seems to be a
>>>> precission problem. think the string used by atof has any problem, but
>>>> I'm not sure
>>> Most computers suffer of this problem.
>>>> What should I do?
>>> You need to learn how to live with that problem :-)
>>>> I tried to change atof(nptr) for strtod(nptr,
>>>> (char**)NULL), but it didn't work...
>>> And it won't help.
>>> Best regards,
>>> Mateusz Loskot
>>> http://mateusz.loskot.net
>> Yes, a stupid problem. I used float instead of double.
> It's not a problem of float vs double.
> Replacing float with double does not guarantee that
> value 0.9 will be represented in memory as 0.9.
> It still can be 0.89999997...
> The float-point term in the docs I suggested does not mean C/C++ type float.
> It means float-point number in arithmetic, which in C/C++ can be float or
> double.
Ok. I changed float for double and now fPixelSize has 0.9, as I want.
But I understand, as you said, that "replacing float with double does
not guarantee that value 0.9 will be represented in memory as 0.9".
So, I'll read again the docs. I find them really interesting.
Many thanks again, Mateusz!
Best regards
Jorge
> Best regards
> Mateusz Loskot
