[gdal-dev] Extract BIGTiff libraries from GDAL source package
Even Rouault even.rouault at mines-paris.org
Sat Jul 25 09:28:21 EDT 2009
make install will also install the headers in $PREFIX/include
Le Saturday 25 July 2009 15:14:11 Enrico Sartorello, vous avez écrit :
> Another question: i've succesfully install BIGTiff from cvs using the usual
> configure-make-make install process.
> But how can i install the header files as well? I've looked on the Makefile
> but can't understand if there's a particular directive to use.
> Thanks in advance,
> On Fri, Jul 24, 2009 at 1:40 PM, Enrico Sartorello <
> enrico.sartorello at gmail.com> wrote:
> > Hi Frank and David,
> > thank you very much for your informations.
> > As you've correctly told, my searches on Google lead me thinking that the
> > Aperio distribution was the right side to get BIGTiff libraries.
> > Now everything is clear to me, thanks for your clarification!
> > Best regards,
> > On Fri, Jul 24, 2009 at 3:12 AM, Frank Warmerdam
<warmerdam at pobox.com>wrote:
> >> David Burken wrote:
> >>> Enrico,
> >>> I like to build straight from cvs:
> >>> cvs -d :pserver:cvsanon at cvs.maptools.org:/cvs/maptools/cvsroot co
> >>> libtiff
> >> Enrico,
> >> I concur with Dave.  The best place to get the latest libtiff4 with
> >> bigtiff support is CVS.  Please note that the Aperio code is a distinct
> >> fork of libtiff and not supported or encouraged for use by the core
> >> libtiff maintainers (ie. me).  It is unfortunate that it places well on
> >> a BigTIFF google search as it has lead several folks astray, including
> >> at least one sizable commercial organization who helped fund the
> >> official libtiff BigTIFF port!
> >> Best regards,
> >>  On 07/23/2009 04:56 AM, Enrico Sartorello wrote:
> >>>> Hi all,
> >>>> i need to have a correct BIGTiff package for using it in a program
> >>>> i've written in C.
> >>>> As far as i can see, the bigtiff package distributed on
> >>>> http://www.aperio.com/bigtiff/ is old and can't be correctly compiled,
> >>>> so i thought i would get it from GDAL.
> >>>> I've seen that BIGTiff is under gdal/frmts/gtiff/libtiff, and i'm even
> >>>> able to make it separately from the rest of GDAL.
> >>>> But make just create a bunch of *.o files from the sources on that dir
> >>>> and nothing more i can use to replace a normal libtiff installation.
> >>>> What do i have to do to get my ready-to-use BIGTiff distribution?
> >>>> Thanks in advance
> >>>> Enrico Sartorello
> >>>> _______________________________________________
> >>>> gdal-dev mailing list
> >>>> gdal-dev at lists.osgeo.org
> >>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> >>------ I set the clouds in motion - turn up   | Frank Warmerdam,
> >> light and sound - activate the windows |
> >> http://pobox.com/~warmerdam<http://pobox.com/%7Ewarmerdam> and watch the
> >> world go round - Rush    | Geospatial Programmer for Rent
> > Enrico Sartorello
