[gdal-dev] Java bindings RuntimeException
Sascha Alexander Jopen jopen at informatik.uni-bonn.de
Sun Jul 26 17:00:27 EDT 2009
Hello,
i was indeed using GCC. Thank you for fixing and commiting the changes
that fast. Know everything works as expected. At least those few methods
i am using.
Sincerely,
Sascha
> Sascha,
> I guess you are compiling with GCC ? If so, it appears that I accidently
> removed some weeks ago a very important compilation flag that I added a few
> months ago, namely -fno-strict-aliasing, that is necessary when compiling
> with -O2. It appears that SWIG generates not-so-correct code in regards to
> the C standard in the upcast methods (  *(foo**)&a = *(bar**)&b ) that the
> compiler can happily completely remove !
> See http://trac.osgeo.org/gdal/changeset/16006 for the revision where it was
> introduced and http://trac.osgeo.org/gdal/changeset/17456 where it has come
> back.
> Thanks for reporting this !
> Best regards,
> Even
