[gdal-dev] BSB borders
Wed Jul 29 01:26:29 EDT 2009
patsv wrote:
> Hi, I am having some problems with finding information about the size of
> the map without the borders in the BSB dataset.
> Is this information available or should I use the GCP points.
Patrik,
I am not sure of a way to identify what is the map collar in a BSB file.
It may be that the information is in the header, but not made available
through GDAL.  I do not believe you can trust the GCPs to define the
map edges for all map sources.
Best regards,
