[Gdal-dev] default pixel size in gdalwarp
Wed Jul 29 01:29:53 EDT 2009
agnes123 wrote:
> Dear all,
> i have one question on the default pixel size in gdalwarp.
> In gdalwarp, we can use -tr to determine output pixel size in x and y
> direction, however, if i omit the argument -tr , gdal will have a default
> pixel size value which is in target projection units.
> For example, if the orginal input raster which has geodetic projection with
> pixel size 0.000277778 (decimal degree), after projecting to Lambert
> Conformal Conic without typing the argument -tr, gdal will have output
> raster pixel size 28.793808m. What is the algorithm behind to obtain the
> value 28.793808?
> I was wondering if there is somebody who knows it. I would greatly
> appreciate it.Thanks!
> Regards,
> Agnes
Agnes,
The computation is done by the GDALSuggestedWarpOutput2() function.  I would
suggest you read it's documentation and if still in doubt scan through the
code.
   http://trac.osgeo.org/gdal/browser/trunk/gdal/alg/gdaltransformer.cpp#L162
It is basically a heuristic to maintain approximately the same diagonal
size of a pixel in the destination coordinate system as it was in the
source coordinate system.
Best regards,
