[gdal-dev] fail gdal autotest rev-17474
Brian Hamlin maplabs at light42.com
Wed Jul 29 03:05:28 EDT 2009
On Jul 28, 2009, at 8:44 PM, Frank Warmerdam wrote:
> Brian Hamlin wrote:
>> its SegFaulting at    gcore/mask.py   mask_5
>> http://paste.debian.net/42924/
> Brian,
> I'm not seeing that problem here.  This this just happen to you
> recently
> after things were working?  Are you using an external system libtiff?
> If
> so, the problem may be that the test exposes bugs in older libtiffs.
> Building with an internal libtiff may be more appropriate for the test
> suite.
ok, I hadnt needed to call out libtiff=internal previously, it seemed
to be doing that already
but, after make clean and a new configure --with-libtiff=internal
the symptom went away...  thanks!
   -Brian
