[gdal-dev] Error in GDAL compiling with HDF4
Limei Ran lran at unc.edu
Wed Jul 29 12:53:10 EDT 2009
Hi:
I am having the following errors when I was compiling GDAL with HDF4 on
a 64bits Linux server:
Command:
 >./configure
--prefix=/nas/uncch/depts/cep/emc/lran/mims/sa_06_2009/src/libs/gdal-1.6.1/local
--with-static-proj4=/nas/uncch/depts/cep/emc/lran/mims/sa_06_2009/src/libs/proj-4.6.1/local
--with-hdf5=/nas/uncch/depts/cep/emc/lran/mims/sa_06_2009/src/libs/hdf5-1.8.3/local
--with-hdf4=/nas/uncch/depts/cep/emc/lran/mims/sa_06_2009/src/libs/HDF4.2r4/local
--without-curl --without-expat --without-mysql --without-dwgdirect
--without-odbc --without-python
Error:
using pre-installed libgif.
checking for cln_GetLayerCapabilities in -logdi31... no
checking for FMEObjects... no
checking for SDreaddata in -lmfhdf... no
checking for SDreaddata in -lhdf4... no
configure: error: HDF4 support requested with arg
"/nas/uncch/depts/cep/emc/lran/mims/sa_06_2009/src/libs/HDF4.2r4/local",
but neither hdf4 nor mfhdf lib found
I compiled HDF4 with: --disable-netcdf --disable-fortran and I did not
compile GDAL with netcdf.  When I got rid of HDF4 in gdal configure, the
configuration went through.
The config.log has a lot of errors related to conftest.c like:
configure:7122: checking how to run the C preprocessor
configure:7162: gcc -E  conftest.c
configure:7168: $? = 0
configure:7199: gcc -E  conftest.c
conftest.c:8:28: error: ac_nonexistent.h: No such file or directory
configure:7205: $? = 1
configure: failed program was:
Could you tell me what went wrong in this gdal compiling with hdf4 ?
Thanks,
Limei
