[gdal-dev] Programmatically writing VRT files
Thu Jul 30 12:22:31 EDT 2009
Andrew Brooks wrote:
> Hello
> I'm trying to write a program to create a VRT file that represents
> raw data held in separate files by following the example in
> http://www.gdal.org/gdal_vrttut.html
> I put a SimpleSource or a VRTRasterBand piece of XML into xml_string
> then, as per the example, I call
>   GDALRasterBand *poBand = poDstDS->GetRasterBand( 1 );
>   poBand->SetMetadataItem( "source_0", xml_string, "vrt_sources" );
> But this gives the error:
> ERROR 1: source_0 metadata item name is not recognized. Should be between source_0 and source_-1
> If I use "new_vrt_sources" then I get no error, but still xml_string
> is not in the output, only <VRTRasterBand dataType="UInt16" band="1"/>
> I've seen the bug  https://trac.osgeo.org/gdal/ticket/3052
> which suggests it is fixed in trunk and I'm using trunk.
> Any other ideas?
Andrew,
Perhaps you could file a ticket with a small script demonstrating the problem?
Best regards,
