[gdal-dev] PNG usage issues
Chaitanya kumar CH chaitanya.ch at gmail.com
Fri Jul 31 06:52:39 EDT 2009
Sam,
This looks like a PNG issue rather than a GDAL one. FYI, versions of libpng
used are libpng1.2.15 in GDAL1.6 and libpng1.2.35 in GDAL trunk. You may
also want to checkout libpng.org
Best regards,
Chaitanya kumar CH.
On Fri, Jul 31, 2009 at 1:42 PM, <ariasgore at gmx.de> wrote:
> Hello,
> we have been using an old gdal version (1.0.x) with our projects, there was
> the png support compiled into the gdal library. Dependency Walker proved
> there were global png_* functions in the gdal library (.dll at this point)
> Due to some issues with png I had to update the png format directory and
> replaced all old png lib files with new ones (the gdal version remained
> unchanged)
> but now the compiled lib does not contain any png related functions
> anymore.
> Same goes for the latest gdal 1.6.x version.
> I was trying to read a png file by including
> png/pngdataset.h which is provided by gdal. during compile and link-time
> this action fails with unresolved symbol errors (in VC it's LNK2019).
> Missing functions are png_create_struct and so on, basically it looks like
> even if the nmake.opt should build and include png as internal lib, there
> are no functions exported with it.
> nmake and everything else have been left with their default values, so I
> dont get, how gdal is supposed to handle png now.
> Thanks
> Sam
> Neu: GMX Doppel-FLAT mit Internet-Flatrate + Telefon-Flatrate
> für nur 19,99 Euro/mtl.!* http://portal.gmx.net/de/go/dsl02
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090731/50614934/attachment.html
