[gdal-dev] GDAL 1.6.2 RC1 Released
    Howard Butler
    hobu.inc at gmail.com
    Fri Jul 31 10:08:02 EDT 2009
All,
The GDAL team is pleased to announce the release of GDAL 1.6.2 RC1.
* http://download.osgeo.org/gdal/gdal-1.6.2-RC1.tar.gz
* http://download.osgeo.org/gdal/gdal162-RC1.zip
The following issues were addressed in this release:
General:
  * OGR expression parser causes access violations with large
expressions (#2996)
  * OGR cannot open/handle .DBF files > 2 GB (#3011)
  * crash in cpl_vsil_win32.cpp when compiling as x64 under Windows
(#3035)
  * create index sql execute problem (#3044)
  * GTiffDataset::FlushCache() cause crashes when used just after
dataset creation (#3067)
  * GDALDefaultOverviews::BuildOverviews() causes out-of-bounds writes
for a 1x1 dataset (#3069)
  * gdaladdo crashes on a 16-bit dataset when external overviews are
requested to have JPEG compression (#3070)
  * Corrupt EXIF info can cause stack buffer overflow in JPEG driver
(#3078)
GDAL:
  * GenBin driver problems (#2730)
  * Additional dependency to libgdal.so added during linking in gdal/
apps (#2970)
  * This NITF Can not be opened (endless loop) with recent GDAL (#3001)
  * This NITF Can not be opened (endless loop) with recent GDAL (#3002)
  * PPM Driver 16bit Support Byte Order Decision Questionable (#3012)
  * GDAL changes projection parameter values (#3017)
  * bad reading of AAIGRID dataset whose last line doesn't have a
linebreak character (#3022)
  * HDF5 Subdataset Issue (#3024)
  * jp2kak driver can't display this unsigned 16 bit J2K image (#3027)
  * NITF PRJPSB TRE handling wrong for Transverse Mercator (#3029)
  * gdaladdo not producing correct overviews for greyscale+alpha image
(#3033)
  * GDALLoadRPB/IMDFile fails with path (#3047)
  * Setting stats and histogram to JP2 compressed NITF corrupts the
aux.xml (#3051)
  * poBand->SetMetadataItem( "source_0", szFilterSourceXML,
"vrt_sources" ) not supported as expected (#3052)
  * gdaladdo fails with JPEG YCBCR when interleaving is not specified
to be pixel (#3064)
  * georaster - NLS problem with XML metadata (#3066)
  * gdalwarp can crash when reprojecting into an irrelevant SRS (#3079)
OGR:
  * Relax KML driver about xmlns (#3004)
  * KML driver painfully slow when reading huge geometries (#3005)
  * PG driver does not recognize 'real' data type (#3006)
  * X-Plane reader: Bezier curves in Pavement and APTLinefeature not
curved (#3030)
OGR Spatial References:
  * Mercator with scale=1 at non-equatoral latitude handled
improperly. (#3026)
  * Hotine Oblique Mercator translation to PROJ.4 format looses scale
factor. (#3032)
  * Equidistant Conic ESRI Morphing Broken (#3086)
Python:
  * OGRFeature.SetField segfault (#3000)
.NET:
  * C# Osr.GetProjectionMethodParameterList / OPTGetParameterList
Access Violation (#3018)
  * [PATCH - C#] Dataset.ReadRaster()/WriteRaster() doesn't work on
multi-band datasets (#3073)
If no significant issues are identified, a PSC vote will be called for
to promote this RC to final on Wednesday or Thursday next week.
Howard
