[gdal-dev] OGR OCI Driver improvement
Nicolas Simon nicolas.simon at spw.wallonie.be
Fri Jul 31 11:08:34 EDT 2009
Franck,
	I'm interested in becoming a longer term contributor for the OCI driver.
	What format do you prefer for fixes ?  Patch format against main trunk ?
	I 'll also provide test to demonstrate the problem and the fix.
	Is there a standard way to provide test suite ?
	Thanks for your advice.
	Nicolas
-----Message d'origine-----
De : Frank Warmerdam [mailto:warmerdam at pobox.com]
Envoyé : mercredi 29 juillet 2009 18:01
À : Nicolas Simon
Cc : gdal-dev at lists.osgeo.org
Objet : Re: [gdal-dev] OGR OCI Driver improvement
Nicolas Simon wrote:
> Dear developpers,
> I use OCI driver for a while and I found some problems
> These problems are blocking for me and I already have solution for some
> of them.
> My firsts questions are organisational.
> What to do to have the code I proposed tested by other people sharing
> the same problem ?
> How to get these patch included in the main trunk for a future release
> of GDAL ?
Nicolas,
Please attach the fixes to the tickets in question (and add yourself to the
cc:list).  Create new tickets for issues for which tickets do not yet exist.
Please ensure fixes are provided against trunk if possible.
If you are interested in becoming a longer term contributor - perhaps with
primary responsibility for the OCI driver - we could pursue that issue after
some of these fixes have at least been reviewed.
Unfortunately, my oracle development environment isn't that conveniently
accessable, but I could drop into it for a bit to try and test and apply
your patches when they are all available.  It would be very helpful for you
to include simple means to demonstrate the problems and confirm the fixes
- ideally leading to additional test suite tests.
Best regards,
