[gdal-dev] GDAL 1.6.2 RC2 Released (was GDAL 1.6.2 RC1 Released)
Howard Butler hobu.inc at gmail.com
Fri Jul 31 15:15:05 EDT 2009
do'h.
* http://download.osgeo.org/gdal/gdal-1.6.2-RC2.tar.gz
* http://download.osgeo.org/gdal/gdal162-RC2.zip
On Jul 31, 2009, at 1:25 PM, Even Rouault wrote:
> Howard,
> I'm afraid you will have to make a RC2 : gcore/gdal_version.h hasn't
> been
> updated.
> Even
> Le Friday 31 July 2009 16:08:02 Howard Butler, vous avez écrit :
>> All,
>> The GDAL team is pleased to announce the release of GDAL 1.6.2 RC1.
>> * http://download.osgeo.org/gdal/gdal-1.6.2-RC1.tar.gz
>> * http://download.osgeo.org/gdal/gdal162-RC1.zip
>> The following issues were addressed in this release:
>> General:
>>  * OGR expression parser causes access violations with large
>> expressions (#2996)
>>  * OGR cannot open/handle .DBF files > 2 GB (#3011)
>>  * crash in cpl_vsil_win32.cpp when compiling as x64 under Windows
>> (#3035)
>>  * create index sql execute problem (#3044)
>>  * GTiffDataset::FlushCache() cause crashes when used just after
>> dataset creation (#3067)
>>  * GDALDefaultOverviews::BuildOverviews() causes out-of-bounds writes
>> for a 1x1 dataset (#3069)
>>  * gdaladdo crashes on a 16-bit dataset when external overviews are
>> requested to have JPEG compression (#3070)
>>  * Corrupt EXIF info can cause stack buffer overflow in JPEG driver
>> (#3078)
>> GDAL:
>>  * GenBin driver problems (#2730)
>>  * Additional dependency to libgdal.so added during linking in gdal/
>> apps (#2970)
>>  * This NITF Can not be opened (endless loop) with recent GDAL
>> (#3001)
>> (#3002)
>>  * PPM Driver 16bit Support Byte Order Decision Questionable (#3012)
>>  * GDAL changes projection parameter values (#3017)
>>  * bad reading of AAIGRID dataset whose last line doesn't have a
>> linebreak character (#3022)
>>  * HDF5 Subdataset Issue (#3024)
>>  * jp2kak driver can't display this unsigned 16 bit J2K image (#3027)
>>  * NITF PRJPSB TRE handling wrong for Transverse Mercator (#3029)
>>  * gdaladdo not producing correct overviews for greyscale+alpha image
>> (#3033)
>>  * GDALLoadRPB/IMDFile fails with path (#3047)
>>  * Setting stats and histogram to JP2 compressed NITF corrupts the
>> aux.xml (#3051)
>>  * poBand->SetMetadataItem( "source_0", szFilterSourceXML,
>> "vrt_sources" ) not supported as expected (#3052)
>>  * gdaladdo fails with JPEG YCBCR when interleaving is not specified
>> to be pixel (#3064)
>>  * georaster - NLS problem with XML metadata (#3066)
>>  * gdalwarp can crash when reprojecting into an irrelevant SRS
>> (#3079)
>> OGR:
>>  * Relax KML driver about xmlns (#3004)
>>  * KML driver painfully slow when reading huge geometries (#3005)
>>  * PG driver does not recognize 'real' data type (#3006)
>>  * X-Plane reader: Bezier curves in Pavement and APTLinefeature not
>> curved (#3030)
>> OGR Spatial References:
>>  * Mercator with scale=1 at non-equatoral latitude handled
>> improperly. (#3026)
>>  * Hotine Oblique Mercator translation to PROJ.4 format looses scale
>> factor. (#3032)
>>  * Equidistant Conic ESRI Morphing Broken (#3086)
>> Python:
>>  * OGRFeature.SetField segfault (#3000)
>> .NET:
>>  * C# Osr.GetProjectionMethodParameterList / OPTGetParameterList
>> Access Violation (#3018)
>>  * [PATCH - C#] Dataset.ReadRaster()/WriteRaster() doesn't work on
>> multi-band datasets (#3073)
>> If no significant issues are identified, a PSC vote will be called
>> for
>> to promote this RC to final on Wednesday or Thursday next week.
>> Howard
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
