[Gdal-dev] C# Osr.GetProjectionMethodParameterList Access Violation
Diaren diarenwhan at yahoo.co.uk
Thu Jun 4 08:06:42 EDT 2009
Further to that the same problem will most likely exist with
CSharp_GetProjectionMethodParamInfo...
Diaren wrote:
> Hi I've been building a projection dialog box in C# Windows, and have come
> across a bug/problem with the generated swig wrappers for
> GetProjectionMethodParameterList / OPTGetParameterList. The problem is
> that the generated Swig Wrapper osr_wrap.cpp frees the Username passed
> back from OPTGetParameterList which is a static string.
View this message in context: http://n2.nabble.com/C--Osr.GetProjectionMethodParameterList-Access-Violation-tp3024324p3024353.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
