[gdal-dev] reload of layer definition without closing dataset
godofredo contreras frdcn at hotmail.com
Thu Jun 4 17:34:09 EDT 2009
Hi:
I'm trying to implement a reestructure layer routine for database datasources. I'm using OGR_DS_ExecuteSQL to send a drop column statement to mysql dataset and it works correctly, it drops the column but the problem is that the layer definition stays the same, how can I force the reload of layer definition without closing and opening the dataset?
Regards
Godofredo Contreras
_________________________________________________________________
Lauren found her dream laptop. Find the PC that’s right for you.
http://www.microsoft.com/windows/choosepc/?ocid=ftp_val_wl_290
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090604/f553030e/attachment.html
