[gdal-dev] Python Scripts
Kyle Shannon ksshannon at gmail.com
Fri Jun 5 19:14:00 EDT 2009
That did the trick, downloaded the current trunk and rebuilt, thanks.
kss
Kyle Shannon
Physical Science Technician
RMRS Fire Sciences Lab
Fire, Fuels & Smoke - RWU 4405
5775 Highway 10 W.
Missoula, MT 59808
(406)829-6954
kshannon at fs.fed.us
On Fri, Jun 5, 2009 at 11:58 AM, Bryan Keith <bryan at ideotrope.org> wrote:
> kss,
> That's in the gdal-dev branch (I don't really know my way around the doe
> repository).  I use both Windows and Linux, and as I recall, it was easier
> for me to get it running in Windows using the OSGeo4W installer then to
> rebuild on Linux.
> I know that's not much info, but maybe it's helpful.
> Bryan
> > Hello all,
> > I am using some srtm data for some modeling and I need to get rid of the
> > no
> > data values.  I checked the trac and found gdal_fillnodata.py.  Seems
> like
> > a
> > good fit, but that script wasn't installed when I built 1.6.1.  Is this
> > script out of date, replaced or available in another form, or do I need
> to
> > rebuild differently?  Thanks.
> > kss
> > Kyle Shannon
> > 5775 Highway 10 W.
> > Missoula, MT 59808
> > (406)829-6954
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090605/3bcb121b/attachment.html
