[gdal-dev] missing nulls in vrt from GRASS rasters
William Kyngesburye woklist at kyngchaos.com
Sat Jun 6 12:48:30 EDT 2009
I created a vrt raster from a set of GRASS rasters - image groups, RGB
+ nulls.  But the nulls are not coming thru in the vrt.  Individually
I get nulls.  Viewing in Qgis the vrt looks like:
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090606/79b58fbe/vrt-0001.png
Each successive image in the vrt overlaps those below it.
But when I add the individual GRASS raster groups to Qgis, it sees the
nulls and lets the earlier images show thru in the overlapping areas.
The GRASS raster bands are all 0-255 greyscale images, and show up in
the vrt as:
   <VRTRasterBand dataType="UInt16" band="1">
     <NoDataValue>2.56000000000000E+02</NoDataValue>
     <ColorInterp>Gray</ColorInterp>
gdalinfo also gives me that 256 for nodata.
In Qgis, the properties for the individual GRASS rasters has
256,256,256 for the transparency band.  So the 256 seems to be right
for the GDAL-GRASS driver for passing nodata/null.
As a test, I tried making a vrt from tiffs with alpha transparency -
same problem, nodata is ignored.  Though for this one, there is no
<NoDataValue> entry in the vrt.
Any idea how I can get the [GRASS] nulls to be recognized in a vrt?
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
[Trillian]  What are you supposed to do WITH a maniacally depressed
robot?
[Marvin]  You think you have problems?  What are you supposed to do if
you ARE a maniacally depressed robot?  No, don't try and answer, I'm
50,000 times more intelligent than you and even I don't know the
answer...
- HitchHiker's Guide to the Galaxy
