[gdal-dev] missing nulls in vrt from GRASS rasters
Even Rouault even.rouault at mines-paris.org
Sat Jun 6 15:37:38 EDT 2009
Le Saturday 06 June 2009 21:24:12 William Kyngesburye, vous avez écrit :
> Will you be backporting this to 1.6 then?  Then I can get it into my
> GDAL framework binaries for OSX until a future 1.6.2 release.
I'm not sure yet. trunk gdalbuildvrt has a new feature (-separate option) and
the change for null values being mixed into that new code doesn't make easy
to backport just it. I also consider it more as a new feature than a true
bugfix. As it is changing the output of gdalbuildvrt, this could be seen as a
unexpected effect for existing users of gdalbuildvrt (unlikely, but who
knows ?). Not to mention that it will give people a good reason for upgrading
to 1.7 when it will be released ;-)
If you really need it, you can just copy gdalbuildvrt.cpp from trunk to 1.6
branch. It should compile just fine I think.
I might change my mind if enough people wish to see it backported and nobody
complains.
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "Mon Dieu! but they are all alike.  Cheating, murdering, lying,
> fighting, and all for things that the beasts of the jungle would not
> deign to possess - money to purchase the effeminate pleasures of
> weaklings.  And yet withal bound down by silly customs that make them
> slaves to their unhappy lot while firm in the belief that they be the
> lords of creation enjoying the only real pleasures of existence....
> - the wisdom of Tarzan
