[gdal-dev] shp-gpx conversion with ogr2ogr
flavio rigolon flavio.rigolon at gmail.com
Mon Jun 8 16:27:04 EDT 2009
> Flavio,
> I found the above syntax worked in trunk, and 1.6 but not in 1.5.  I
> suspect
> you are using 1.5.x or earlier binaries that do not support the AS operator
> for renaming fields.
Frank,
 thanks! You're right. I'm using 1.5 version.
I will try with 1.6
regards
flavio
io uso Debian GNU/Linux
user #413018 counter.li.org
<<usiamo formati aperti!>>
http://it.wikipedia.org/wiki/Formato_aperto
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090608/c750d3d5/attachment.html
