[gdal-dev] memory leak in hdf driver
Vincent Schut schut at sarvision.nl
Tue Jun 9 08:41:46 EDT 2009
issue filed as http://trac.osgeo.org/gdal/ticket/3023
Vincent Schut wrote:
> Hi,
> I'm afraid I've encountered a memory leak in the hdf driver.
> Context: because of massive parallel (cluster) processing, I'm reusing
> a python instance for lots of jobs. Some of these jobs use gdal to
> read and/or save data. In some cases, I saw the memory use of my
> python worker processes grow with each job, until the whole lot got
> killed. I've got 8 gig on that server :-). I've been able to track
> down the leak to the use of gdal.Open on a hdf (modis) dataset. I
> guess this means that either the gdal hdf driver or libhdf4 has the leak.
> Here is some python code (runs on linux only due to the code to get
> the mem usage) to prove a leak when opening a hdf file, while no leak
> when opening a tif. Run in a folder with 'data.hdf' and 'data.tif'
> present, or change those names to an existing hdf and tif file.
> Using 64bit linux, gdal svn rev. 17228 (today), libhdf4.2r2, python 2.6.2
> I'll file a bug for this issue.
> ========= python code =========
> import os
> from osgeo import gdal
> def getmemory():
>    proc_status = '/proc/%d/status' % os.getpid()
>    scale = {'kB': 1024.0, 'mB': 1024.0*1024.0,
>          'KB': 1024.0, 'MB': 1024.0*1024.0}
>    v = open(proc_status).read()
>    i = v.index('VmSize:')
>    v = v[i:].split(None, 3)
>    return (int(v[1]) * scale[v[2]])
> nFiles = 100
> m0 = getmemory()
> print 'memory usage before:', m0
> print
> print nFiles, 'times the same hdf file'
> for i in range(nFiles):
>    gdal.OpenShared('data.hdf')
> m1 = getmemory()
> print 'memory usage now:', m1, '  difference:', m1-m0
> print
> print nFiles, 'times the same tif file'
>    gdal.OpenShared('data.tif')
> m2 = getmemory()
> print 'memory usage now:', m2, '  difference:', m2-m1
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
