[gdal-dev] OGR and database filter on spatial extent
Thu Jun 11 13:29:24 EDT 2009
Brent Fraser wrote:
> Frank,
>  > Brent,
>> Any time you provide your own SQL it will be executed unaltered.  The
>> spatial and attribute filters are only automatically built into the
>> select statement when the select statement is constructed internally
>> by OGR.
>> OGR makes *no attempt at all* to interprete provided SQL (via
>> ExecuteSQL()
>> or <SrcSQL>.  So it has no idea what tables it relates to or how any
>> restrictions could be added.
> I guess that's technically true, but ogr (likely the VRT parser) gives
> an error when I try to construct my own spatial filter:
> <SrcSQL>SELECT * FROM alta83_v1 WHERE BOT_LONG > -114 AND BOT_LONG <
> -113 AND BOT_LAT > 51 AND BOT_LAT < 52</SrcSQL>
> ERROR 1: Line 4: Didn't find expected '=' for value of attribute 'AND'.
> I expect it doesn't like the ">".  Quoting the SQL and bracketing the
> where clause portion doesn't help.   Perhaps there's an escape sequence
> I could use?
Brent,
You need to use normal XML escaping.  I imagine that is &gt; and &lt; for
the comparison operators.
> And is there point in constructing a view with columns of WKT geometry,
> XMIN, YMIN, XMAX and YMAX to see if the ODBC driver would take advantage
> of those?
Not if you are going to use SrcSQL - no.  If you provide your own SQL, then
no automatic spatial filtering will take place in the database - it will be
done after fetching all rows.
Best regards,
