[gdal-dev] Can we copy RPC from NITF file to a newly created NITF file ?
Francesco Paolo Lovergine frankie at debian.org
Tue Jun 16 11:36:44 EDT 2009
On Wed, Jun 10, 2009 at 04:04:10PM -0500, Ozy Sjahputera wrote:
> I have an NITF image in UTM projection, but its RPC appears to be
> intended for LatLon. I tried to perform orthorectification on this image
> using orthoigen from OSSIM, but the result was weird (panchromatic and
> multispectral become non-overlapping).
Panchromatic and multispectrals have different spatial resolutions.
Did you use the same grid resolution for ortho-rect both them?
> I plan to reproject this image
> to LatLon hoping that it will work well with the available RPC. However,
> can do I transfer the RPC from original image to the new image? Should
> the new image be in NITF as well to accommodate the RPC?
Francesco P. Lovergine
