[gdal-dev] Build OGR with Oracle support
Mateusz Loskot mateusz at loskot.net
Tue Jun 16 16:40:54 EDT 2009
Normand Savard wrote:
> I checked in the configure.in script and everything seems alright.
> Could someone gives me some hints about why the library is not found?
> /home/fgs/fgs-dev/built/instantclient_11_1... norm:
> -L/home/fgs/fgs-dev/built/instantclient_11_1 -lclntsh
> norm: -I/home/fgs/fgs-dev/built/instantclient_11_1/sdk/include
> not found
> checking if Oracle support is enabled... no
> checking Checking for DODS... disabled
./configure generates a log file called config.log.
If something goes wrong, there should be some diagnostic in this file.
It would be helpful if you could share it, for instance, here:
http://pastebin.com/
This will help to find what's the problem.
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
Charter Member of OSGeo, http://osgeo.org
