[gdal-dev] Curve support in OGR
Andreas Neumann a.neumann at carto.net
Wed Jun 17 05:15:28 EDT 2009
Hi all,
I am sure this topic is coming up once in a while. I wonder what the
take is on curve support in the OGR feature model.
Most formats we use now support curves, but our favorite translation
engine does not. For curve support I currently have to use FME.
These are the formats/databases we use:
Postgis (Geodata Warehouse)
Oracle Spatial (production system for survey data, linked to Autodesk
Topobase)
dxf/dwg (file exchange)
SVG (presentation format)
sdf (used for Mapguide)
Most of our survey data contains circular arcs, some datasets also
contain splines.
I know that curve support in Postgis is somehow limited, but each
release improves a bit on it and the list of curve-aware operators is
growing:
http://postgis.refractions.net/documentation/manual-svn/ch08.html#PostGIS_Curved_GeometryFunctions
If OS GIS wants to further penetrate in Switzerland it has to be able to
deal with curves (at least circular arcs) since they are used all over
the place.
Of course we are willing to partially help to finance such a development
(hopefully with some others) if the OGR developers are interested in
adding curve support and can offer an estimate on how much it would cost
to implement this (at least on the core and for selected formats).
Thanks,
Andreas
