[gdal-dev] GDAL/ArcObjects based app crashes with newer GDAL versions (was How to delete shapefile)
Clay, Bruce bclay at ball.com
Wed Jun 17 14:59:24 EDT 2009
Mateusz:
Yes that is the case.  The same application works fine with GDAL 1.5.4
but not with any newer version.
I am beginning to suspect SDE / GDAL interaction.  I think SDE uses GDAL
1.4.  My GDAL library is built with SDE support and I am linking in
ArcObjects libraries to my application.  I am linking to the GDAL static
library when the crash occurs.  If I try to link to the gdal_i.lib then
the program does not crash but it does not let me step into any of the
methods even though it is a debug library and no GDAL functions work.
You mentioned "configuration".  Does GDAL 1.6 and new code require some
configuration on Windows XP that was not required before?
Bruce
-----Original Message-----
From: Mateusz Loskot [mailto:mateusz at loskot.net]
Sent: Wednesday, June 17, 2009 1:15 PM
To: Clay, Bruce
Cc: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] How to delete shapefile
Clay, Bruce wrote:
> Mateusz:
>   Thanks for your reply.  Unfortunately I can not get far enough to do
> that.  The crash is occurring down stream from OGRRegisterAll.  That
is
> to say, the last call in my code space before the crash is
> OGRRegisterAll. I can not get OGR initialized to be able to open a
data
> source.
Bruce,
Are you saying that you are unable to run this simple program
successfully?
#include "ogrsf_frmts.h"
int main()
     OGRRegisterAll();
If you indeed can not run it, it probably means your GDAL installation
is not configured properly or broken.
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
This message and any enclosures are intended only for the addressee.  Please
notify the sender by email if you are not the intended recipient.  If you are
not the intended recipient, you may not use, copy, disclose, or distribute this
message or its contents or enclosures to any other person and any such actions
may be unlawful.  Ball reserves the right to monitor and review all messages
and enclosures sent to or from this email address.
