[gdal-dev] gdaladdo
Dillabough, Craig Craig.Dillabough at AGR.GC.CA
Thu Jun 18 15:50:25 EDT 2009
I am trying to tile and create overviews for a TIFF image dataset I
have, but I keep getting strange errors when attempting to add
overviews.
1st I created a copy of the original image (same format and all, but
wanted to keep the original around in case I had problems).
>gdal_translate -ot Float32 -of GTiff Av.MaxNDVI.2000.2009.Week.19.tif
trans/week19.tif
>cd trans
Then I tiled the image (I guess I could have done this in one step by
adding -co "TILED=YES" to the previous step):
>gdal_translate -ot Float32 -of GTiff -co "TILED=YES" week19.tif
week19_tiled.tif
Then I tried to add the overviews:
> gdaladdo -r average -ro week19_tiled.tif 2 4 8 16
I get the following (I've added some whitespace for clarity):
0...10...20...30...40...50...60...70...
Warning 1: TIFFReadDirectory:week19_tiled.tif.ovr: Wrong
"StripByteCounts" field,
ignoring and calculating from imagelength
ERROR 1: week19_tiled.tif.ovr:DumpModeDecode: Not enough data for
scanline 0
ERROR 1: TIFFReadEncodedTile() failed.
ERROR 1: IReadBlock failed at X offset 0, Y offset 3
ERROR 1: GetBlockRef failed at X block offset 0, Y block offset 3
I get effectively the same error when I run this without the -ro option.
Any idea's what is going wrong.
Regards,
Craig Dillabaugh
