[gdal-dev] Errors in compiling GDAL on a 64bits Linux
Chandra Shekhar Kumar chandra.kumar at flagstonere.bm
Thu Jun 18 15:50:28 EDT 2009
>/afs/isis.unc.edu/pkg/oracle-1020/client//lib/libexpat.so: could not
>read symbols: File
>in wrong format
>collect2: ld returned 1 exit status
>make[1]: *** [libgdal.la] Error 1
[Chandra ] it looks like it is getting linked against 32-bit libexpat.so
Can you check the same by "file <path-to-libexpat>/libexpat.so" and let
me know the result of the same ?
This communication contains information which is confidential and may also be legally privileged. It is for the exclusive use of the intended recipient(s). If you are not the intended recipient(s), disclosure, copying, distribution, or other use of, or action taken or omitted to be taken in reliance upon, this communication or the information in it is prohibited and maybe unlawful. If you have received this communication in error please notify the sender by return email, delete it from your system and destroy any copies.
