[gdal-dev] Setting GDAL Http Fetcher
Joel Odom joelodom at gmail.com
Thu Jun 18 17:42:44 EDT 2009
No mind readers here?  :-)  Let me explain.
The WMS data source uses libcurl to fetch http requests.  I'd like to put a
different engine in to fetch http requests so that I can handle some other
protocols (actually I'm using libcurl myself with some helper functions).  I
was wondering if I could instruct the WMS data source to use the methods
that I have to fetch http requests instead of using its internal handlers.
 Thanks!
On Thu, Jun 18, 2009 at 4:47 PM, Even Rouault
<even.rouault at mines-paris.org>wrote:
> I don't understand your question. You should provide more details on what
> you
> want to do exactly
> Le Thursday 18 June 2009 18:31:20 Joel Odom, vous avez écrit :
> > Can I programatically change the http fetcher that GDAL uses for WMS
> > without recompiling GDAL?  Thanks!
http://giscoder.blogspot.com/
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090618/ec5a2a98/attachment-0001.html
