[gdal-dev] Setting GDAL Http Fetcher
Even Rouault even.rouault at mines-paris.org
Thu Jun 18 17:52:54 EDT 2009
You need to hack into GDAL itself then.
Le Thursday 18 June 2009 23:42:44 Joel Odom, vous avez écrit :
> No mind readers here?  :-)  Let me explain.
> The WMS data source uses libcurl to fetch http requests.  I'd like to put a
> different engine in to fetch http requests so that I can handle some other
> protocols (actually I'm using libcurl myself with some helper functions).
> I was wondering if I could instruct the WMS data source to use the methods
> that I have to fetch http requests instead of using its internal handlers.
> Thanks!
> On Thu, Jun 18, 2009 at 4:47 PM, Even Rouault
> <even.rouault at mines-paris.org>wrote:
> > I don't understand your question. You should provide more details on what
> > you
> > want to do exactly
> > Le Thursday 18 June 2009 18:31:20 Joel Odom, vous avez écrit :
> > > Can I programatically change the http fetcher that GDAL uses for WMS
> > > without recompiling GDAL?  Thanks!
