[gdal-dev] Build OGR with Oracle support
Normand Savard nsavard at mapgears.com
Fri Jun 19 11:19:22 EDT 2009
Andreas Neumann wrote:
> Hi,
> I was trying to get OCI support on my Ubuntu server and followed your
> instructions.
> I am struggling with the libnnz10.so: libnnz10.so is present and I also
> set the LD_LIBRARY_PATH accordingly.
> But the configure script still fails. In the config.log I get the
> following messages:
> /usr/bin/ld: warning: libnnz10.so, needed by
> /usr/local/lib/instantclient_10_2/libclntsh.so, not found (try using
>  -rpath or -rpath-link)
> /usr/local/lib/instantclient_10_2/libclntsh.so: undefined reference to
> `nzos_ModifyCipherSuites'
> `nzosCipherSpecToStr'
> `nzos_Initialize'
> `nzosgpc_GetProtocolVer'
> `nztwOpenWallet'
> `A_X931RandomInit'
> `nzosGetSupportedCipher'
> `nzos_ServiceWriteQueue'
> `nzos_DisableClientAuthentication'
> `nztiGetSecInfo'
> `nzos_Write'
> `nzduui2_destroy_ui'
> `_intel_fast_memset'
> `nztGetSubjectName'
> `nzgbllsm_location_shared_memory'
> `nzos_setThrUse'
> `nzteMyCert'
> `nzteDestroyPersona'
> `nzos_RetrievePersonaCopy'
> `nzosSCCS_SetCRLCacheSize'
> `nztnGCL_Get_Certificate_List'
> `nzos_setCRLFile'
> `A_X931RandomContextDestroy'
> `nzos_OToolkitContext'
> more messages ......
> collect2: ld returned 1 exit status
> configure:24161: $? = 1
> configure: failed program was:
> |                 /* confdefs.h.  */
> | #define PACKAGE_NAME ""
> | #define PACKAGE_TARNAME ""
> | #define PACKAGE_VERSION ""
> | #define PACKAGE_STRING ""
> | #define PACKAGE_BUGREPORT ""
> | #define STDC_HEADERS 1
> Any idea why it can't find libnnz10.so despite it being present and the
> LD_LIBRARY_PATH set?
> Here are my configure-params:
> ./configure --with-python --with-perl --with-php --with-curl --with-expat
> --with-pg=/usr/local/pgsql/bin/pg_config --with-xerces
> --with-grass=/usr/local/grass-6.4.0RC2/
> --with-oci-include=/usr/local/lib/instantclient_10_2/sdk/include
> --with-oci-lib=/usr/local/lib/instantclient_10_2
Andrea,
I was thinking of one other thing.  It is good to set LD_LIBRARY_PATH
variable but  you  have to export it.  For instance, for FGS I needed to
do something like this:
    export LD_LIBRARY_PATH=$FGS_BUILD_HOME/$oci_ARCHIVE_DIR:$LD_LIBRARY_PATH
Norm
