[gdal-dev] moving filter averaging in GDAL.
Belaid MOA belaid_moa at hotmail.com
Fri Jun 19 13:50:02 EDT 2009
Thank you very much Even. I was just making sure I am not reinventing the wheel :).
I will then write the C++ version.
With best regards.
~Belaid...
> From: even.rouault at mines-paris.org
> To: gdal-dev at lists.osgeo.org
> Subject: Re: [gdal-dev] moving filter averaging in GDAL.
> Date: Fri, 19 Jun 2009 19:44:10 +0200
> CC: belaid_moa at hotmail.com
> It should be relatively straighforward to transpose from Python to C++, as
> Python API is mostly deduced from the original C++ one. Look at the
> documentation of the C++ API on gdal.org
> Le Friday 19 June 2009 19:27:40 Belaid MOA, vous avez écrit :
> > Thanks a lot Frank. Is there any C/C++ version for that? I am doing the
> > averaging filter from C++ code.
> > With best regards.
> > Belaid Moa.
> > > Date: Fri, 19 Jun 2009 13:23:33 -0400
> > > From: warmerdam at pobox.com
> > > To: belaid_moa at hotmail.com
> > > CC: gdal-dev at lists.osgeo.org
> > > Belaid MOA wrote:
> > > > Hi,
> > > >  Does GDAL have functions for applying an averaging filter of window,
> > > > say 11x11, to an image? This is something that comes up all the time in
> > > > image analysis. So, I suppose GDAL has built-in functions for that.
> > > >  Any help on this is very appreciated.
> > > Belaid,
> > > There is support for filtering, including average filtering, with the
> > > gdalfilter.py command in gdal/swig/python/samples.  It accomplished
> > > by creating a virtual file using the <KernelFilteredSource> directive -
> > > so ultimately the work is done by the VRT driver.
> > > Best regards,
> > >----- I set the clouds in motion - turn up   | Frank Warmerdam,
> > > warmerdam at pobox.com light and sound - activate the windows |
> > > http://pobox.com/~warmerdam and watch the world go round - Rush    |
> > > Geospatial Programmer for Rent
> > _________________________________________________________________
> > We are your photos. Share us now with Windows Live Photos.
> > http://go.microsoft.com/?linkid=9666047
Attention all humans. We are your photos. Free us.
http://go.microsoft.com/?linkid=9666046
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090619/0eaf9ddf/attachment.html
