[gdal-dev] GDAL Python API translation options for clipping an image?
Sat Jun 20 06:57:43 EDT 2009
Bob Bruce wrote:
> Hi:
> 	I am working on a Quantum GIS plugin to clip individual images.
> I am trying to figure out how to issue a command from the Python API
> which is the equivalent of:
> gdal_translate -a_srs "EPSG:26914" -a_nodata 0 -of GTiff -prjwin 370600
> 6021200 327700 6023350 MB07005-83-R-modified.tif
> MB07005-83-R-modifiedTrim.tif
> I see that the creation options are accessible in the CreateCopy method
> of the GDALDriver class but I cannot see where the other GDAL_translate
> options are available. What should I do to perform this kind of
> translation via the GDAL Python API?
Bob,
The gdal_translate command accomplishes this by constructing an
intermediate virtual dataset which references only a subwindow
of the source dataset.  This is also how it accomplishes band
subsetting/rearranging.  I would suggest you skim the gdal_translate
code to get a sense of how this is accomplished.
Looking at gdal_translate I see it uses direct access to the VRT
API to accomplish some of the steps to construct a virtual dataset.
I don't think this API is exposed in Python, but the same effect can
be accomplished by assembling VRT XML as described at:
   http://www.gdal.org/gdal_vrttut.html
You might also find it helpful to review the code for the OpenEV Export
Tool which provides functionality fairly similar to gdal_translate from a
Python managed GUI.  It also construct VRT XML.  Hmm, on reflection I see
OpenEV abstracts most of the VRT portion of things into a vrtutils.py
module that might be useful with modification. I have attached it for
reference,
Best regards,
Type: text/x-python
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090620/b4e325b8/vrtutils-0001.py
