[gdal-dev] Fwd: configuring gdal to support hdf
Benjamin Welton benjamin.r.welton at wmich.edu
Sun Jun 21 12:59:01 EDT 2009
When doing ./configure are you adding the proper flag for the hdf
version you plan to use (--with-hdf4 and --with-hdf5)? Also have you
tried setting the locations of the library's by doing
--with-hdf4=<library location>?
Ben
Mateusz Loskot wrote:
> Olivier Pilotte wrote:
>> I'm unable to configure gdal to support the hdf file format.
>> Any suggestions ?
> No details, no suggestion.
> Best regards,
