[gdal-dev] Tests fail on buildbot
Mateusz Loskot mateusz at loskot.net
Sun Jun 21 08:08:49 EDT 2009
I've noticed tests fail on most builders and there is message like this:
"As GDAL_DOWNLOAD_TEST_DATA environment variable is not defined, 40
tests relying on data to downloaded from the Web have been skipped"
Is this something I should configure for GDAL on Buildbot?
If yes, what values should I set for this env variable?
Cheers
Mateusz Loskot, http://mateusz.loskot.net
Charter Member of OSGeo, http://osgeo.org
