[gdal-dev] Tests fail on buildbot
Sun Jun 21 13:22:12 EDT 2009
Mateusz Loskot wrote:
> Hi,
> I've noticed tests fail on most builders and there is message like this:
> "As GDAL_DOWNLOAD_TEST_DATA environment variable is not defined, 40
> tests relying on data to downloaded from the Web have been skipped"
> Is this something I should configure for GDAL on Buildbot?
> If yes, what values should I set for this env variable?
Mateusz,
I'd prefer we not enable this while the build slaves are still on
buildbot.osgeo.org.  This could be turned on when the slaves have
been migrated to buildtest.osgeo.org.
The errors I notice on the windows tests are just a wms connection problem
and there isn't really much action to address them.
Best regards,
