Re [Gdal-dev] : GDAL problems with IDLE
JPKay kay1829 at vandals.uidaho.edu
Mon Jun 22 17:55:38 EDT 2009
I did that already, but it does not want to respond with IDLE, I get the same
error.
salwa wrote:
> Hi,
> try the the following steps
> http://pypi.python.org/pypi/GDAL/
> --- En date de : Lun 22.6.09, JPKay <kay1829 at vandals.uidaho.edu> a écrit :
> De: JPKay <kay1829 at vandals.uidaho.edu>
> Objet: [Gdal-dev] GDAL problems with IDLE
> À: gdal-dev at lists.osgeo.org
> Date: Lundi 22 Juin 2009, 21h47
> Hello,
> I am trying to install GDAL on my mac running OS x 10.5.7 using python
> 2.5.4. I have followed the directions to build from the cheese shop,
> however
> when I go over to IDLE and try  the command "from osgeo import ogr" I get
> the following error: ImportError: No module named osgeo. I assume this
> means
> that the libraries can't find each other. Any thoughts on this topic would
> be appreciated.
> Thanks in advance,
> Jon
> http://n2.nabble.com/GDAL-problems-with-IDLE-tp3138630p3138630.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
View this message in context: http://n2.nabble.com/Re-%3A-GDAL-problems-with-IDLE-tp3138971p3138989.html
