[gdal-dev] convert kmz to shapefiles
maning sambale emmanuel.sambale at gmail.com
Wed Jun 24 21:31:36 EDT 2009
I tried to decompress the kmz nd converted the doc.kml.  ogr2ogr did
not convert the kml (for good reasons) because it is a mixture of
placemark, polygons and lines
On Thu, Jun 25, 2009 at 12:38 AM, Craig
Miller<craig.miller at spatialminds.com> wrote:
> Have you tried GPS Babel?
> From: "maning sambale" <emmanuel.sambale at gmail.com>
> Sent: Wednesday, June 24, 2009 3:00 AM
> To: <gdal-dev at lists.osgeo.org>
> Subject: [gdal-dev] convert kmz to shapefiles
>> Hi,
>> I tried converting kmz (compressed kml) to shapefile but it is not
>> recognized by ogr2ogr.  Any workaround the list can suggest?
>> cheers,
>> maning
>> "Freedom is still the most radical idea of all" -N.Branden
>> wiki: http://esambale.wikispaces.com/
>> blog: http://epsg4253.wordpress.com/
>> gdal-dev mailing list
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
cheers,
maning
