[gdal-dev] running gdal_merge for a lot of files
Fri Jun 26 09:33:33 EDT 2009
Pavel Iacovlev wrote:
> Good day all,
> I am trying to merge a large data set, the input imagery is 1TB RGB
> uncompressed tifs (lots of them). Then I run gdal_merge.py on a small
> data set it runs ok and with -v option I can see whats happening. But
> then I run on a large dataset I don't get no verbose output (I don't
> get no output at all) and it stuck on 8.9 GB image size. I can just
> track that the image is getting bigger but not verbose output
> whatsoever and I can tell why it stops on 8.9 GB.
> My command is: gdal_merge.py -v -init 255 -of GTiff -co TILED=YES -co
> COMPRESS=JPEG -co PHOTOMETRIC=YCBCR -co BIGTIFF=YES -o of.tif of/*.tif
> The input images are around 160mb each so loading them 1 by 1 into
> memory is not a problem.
Pavel,
I don't know what is going wrong.  I would suggest adding lots of print
statements in the gdal_merge.py script to try and establish where it is
freezing up.
Best regards,
