[gdal-dev] PackBitsDecode: Not enough data ...
Hermann Peifer peifer at gmx.eu
Tue Jun 30 10:06:52 EDT 2009
Hi.
I am trying to warp a GeoTiff from EPSG:3035 to EPSG:4326. After 50%
done, I end up with the following errors:
$ gdalwarp -t_srs EPSG:4326 lceugr100_00_pct.tif
lceugr100_00_pct_epsg4326.tif -co COMPRESS=PACKBITS
Copying color table from lceugr100_00_pct.tif to new file.
Creating output file that is 121261P x 44229L.
Processing input file lceugr100_00_pct.tif.
0...10...20...30...40...50..ERROR 1:
lceugr100_00_pct_epsg4326.tif:PackBitsDecode: Not enough data for
scanline 22054
ERROR 1: TIFFReadEncodedStrip() failed.
ERROR 1: IReadBlock failed at X offset 0, Y offset 22054
ERROR 1: GetBlockRef failed at X block offset 0, Y block offset 22054
Is there any issue with the decoding the PACKBITS compression?
Hermann
$ gdalinfo lceugr100_00_pct.tif
Driver: GTiff/GeoTIFF
Files: lceugr100_00_pct.tif
        lceugr100_00_pct.aux
Size is 67000, 58000
Coordinate System is:
PROJCS["ETRS_1989_LAEA_L52_M10",
     GEOGCS["GCS_ETRS_1989",
         DATUM["European_Terrestrial_Reference_System_1989",
             SPHEROID["GRS_1980",6378137.0,298.257222101]],
         PRIMEM["Greenwich",0.0],
         UNIT["Degree",0.0174532925199433]],
     PROJECTION["Lambert_Azimuthal_Equal_Area"],
     PARAMETER["False_Easting",4321000.0],
     PARAMETER["False_Northing",3210000.0],
     PARAMETER["Central_Meridian",10.0],
     PARAMETER["Latitude_Of_Origin",52.0],
     UNIT["Meter",1.0]]
Origin = (800000.000000000000000,6500000.000000000000000)
Pixel Size = (100.000000000000000,-100.000000000000000)
Metadata:
   AREA_OR_POINT=Area
Image Structure Metadata:
   COMPRESSION=PACKBITS
   INTERLEAVE=BAND
Corner Coordinates:
Upper Left  (  800000.000, 6500000.000) ( 72d48'20.05"W, 59d 5'6.85"N)
Lower Left  (  800000.000,  700000.000) ( 24d 7'20.21"W, 22d12'54.64"N)
Upper Right ( 7500000.000, 6500000.000) ( 90d22'56.28"E, 61d55'58.94"N)
Lower Right ( 7500000.000,  700000.000) ( 41d 0'50.13"E, 23d29'5.23"N)
Center      ( 4150000.000, 3600000.000) (  7d17'47.28"E, 55d28'33.08"N)
Band 1 Block=67000x1 Type=Byte, ColorInterp=Palette
   Metadata:
     LAYER_TYPE=thematic
   Color Table (RGB with 256 entries)
