[gdal-dev] Trouble installing gdal 1.6.1
Adeel Raza adeel.raza at crc.gc.ca
Tue Jun 30 12:01:04 EDT 2009
Thanks.
Jeff McKenna wrote:
> Adeel Raza wrote:
>> Hi,
>> I compiled gdal 1.6.1 for MSVC 9.0 and then I wrote the following
>> command to install the library files in the desired directory. I get
>> the following error:
>> D:\gdal-1.6.1> nmake /f makefile.vc install GDAL_HOME=D:\gdal
>> Microsoft (R) Program Maintenance Utility Version 9.00.30729.01
>> Copyright (C) Microsoft Corporation.  All rights reserved.
>>       if exist gdal.lib del gdal.lib
>>       lib /nologo /out:gdal.lib port\*.obj gcore\*.obj alg\*.obj
>> frmts\o\*.obj
>> ogr\ogrsf_frmts\ogrsf_frmts.lib ogr\ogr.lib vb6\vb6_support.obj
>> LINK : fatal error LNK1181: cannot open input file 'vb6\vb6_support.obj'
>> NMAKE : fatal error U1077: '"C:\Softwares\Microsoft Visual C++ 2008
>> Express Edit
>> ion\VC\BIN\lib.EXE"' : return code '0x49d'
>> Stop.
> Once you set the MSVC_VER value in the nmake.opt, then you can also
> set the install directory (see lines ~44-50)...set those, save, and
> execute 'nmake /f makefile.vc' and then 'nmake /f makefile.vc install'.
> -jeff
