[gdal-dev] GDAL autotest failures on Windows
Tamas Szekeres szekerest at gmail.com
Sun Mar 1 10:24:02 EST 2009
Hi Folks,
I've managed to include the GDAL auto-tests with my regular builds on
Windows. The stable branch has no failures.
The SVN trunk  produces 17-18 failures for each compilers/architectures:
------------ Failures ------------
Script: ogr/ogr_gml_read.py
  TEST: ogr_gml_4 ... fail
    Wrong featureCode field value
Script: gcore/hfa_write.py
  TEST: SetProjection: byte.tif ... fail
    Did not get expected projection reference.
  TEST: SetProjection: int16.tif ... fail
  TEST: SetProjection: uint16.tif ... fail
  TEST: SetProjection: int32.tif ... fail
  TEST: SetProjection: uint32.tif ... fail
  TEST: SetProjection: float32.tif ... fail
  TEST: SetProjection: float64.tif ... fail
  TEST: SetProjection: cfloat32.tif ... fail
  TEST: SetProjection: cfloat64.tif ... fail
  TEST: SetProjection: utmsmall.tif ... fail
Script: gcore/misc.py
  TEST: misc_5 ... fail (blowup)
  TEST: misc_6 ... fail (blowup)
Script: gdrivers/aigrid.py
  TEST: aigrid_online_1 ... fail
    No RAT found
Script: gdrivers/bsb.py
  TEST: bsb_online_1 ... fail
    Checksum for band 1 in "tmp/cache/14850_1.KAP" is 63005, but expected 54674.
Script: gdrivers/hfa.py
  TEST: hfa_delete_colortable ... fail (blowup)
Script: osr/osr_esri.py
  TEST: osr_esri_15 ... fail
    Did not get rectified_grid_angle as expected.
  TEST: osr_esri_16 ... fail
    Did not get expected equidistant cylindrical.
Test Script: utilities/test_ogrtindex.py
Succeeded: 1287
Failed:    18 (3 blew exceptions)
Skipped:   238
Expected fail:0
For more details about the issues you can inspect the build logs here:
http://vbkto.dyndns.org:1280/sdk/index.html
Best regards,
Tamas
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090301/858fb183/attachment.html
