[gdal-dev] SRS-Transformation(DHDN/GK=>ETRS89/UTM) with towgs84 - Accuracy
Gregor Fikoczek gregor.fikoczek at wheregroup.com
Wed Mar 4 09:53:29 EST 2009
Hi list,
i figured out why the accuracy was so bad using the towgs84-Option:
the scaling was not in parts per million indicated
wrong scaling-specification:
=> 1.00001651559
ogr2ogr -s_srs "+proj=tmerc +lat_0=0 +lon_0=6 +x_0=2500000 +y_0=0
+ellps=bessel +units=m
+towgs84=590.1181,99.6226,340.1890,1.185095,-1.334952,-2.904521,1.00001651559" -t_srs "+proj=utm
+ellps=GRS80 +datum=WGS84 +zone=32" -f GML points_7P_gdal.gml points.gml
right scaling-specification:
=> 16.51559 (ppm)
+towgs84=590.1181,99.6226,340.1890,1.185095,-1.334952,-2.904521,16.51559" -t_srs "+proj=utm
Results 					|		difference
East[m]	     |	North[m]		|	E	    |	   N	    |  distance
340408,046	5617072,499		-0,013	-0,012	0,018
342695,227	5614819,736		0,003	0,013	0,013
343584,887	5608927,612		0,014	0,026	0,030
Accuracy:
  ~ 0.3	m
Best Regards,
Greg
>----------  Weitergeleitete Nachricht  ----------
>Betreff: SRS-Transformation(DHDN/GK=>ETRS89/UTM) with towgs84 - Accuracy
>Datum: Mittwoch 04 März 2009
>Von: Gregor Fikoczek <gregor.fikoczek at wheregroup.com>
>An: gdal-dev at lists.osgeo.org
>Hi list,
>i am trying to transform some point (in a gml-file) from DHDN/GK3 - srs  to
>ETRS89/UTM - srs in some diferent ways:
>some points(gml-File) in start-srs
>Pointnr.	     |		X[m]	      |		Y[m]
>5216100002 |	2552401,862    |	5616707,524
>5414100047 |	2554778,697    |	5614549,001
>5508100055 |	2555906,314    |	5608696,986
>some points(gml-File) in target-srs
>Punktnr.	      | 	East[m]	| 	North[m]
>5216100002	32340408,033		5617072,487
>5414100047	32342695,230		5614819,749
>5508100055	32343584,901		5608927,638
>1.) using the srs defined in the proj-epsg-File:
>ogr2ogr -s_srs EPSG:31466 -t_srs EPSG:25832 -f GML points_etrs_gdal.gml
>points.gml
>340411,269  |	5617068,431	|	-3,236  |	4,056   |	5,188
>342698,445  |	5614815,708	|	-3,215  |	4,041   |	5,164
>343588,142  |	5608923,646	|	-3,241  |	3,992   |	5,142
>2.) using a nadgrid (BETA 2007)
>ogr2ogr -s_srs "+proj=tmerc +lat_0=0 +lon_0=6 +k=1.000000 +x_0=2500000 +y_0=0
>+ellps=bessel +units=m +nadgrids=./BETA2007.gsb +wktext" -t_srs "+proj=utm
>+ellps=GRS80 +datum=WGS84 +zone=32" -f GML points_BETA2007_gdal.gml
>points.gml
>340408,064  |	5617072,481	|	-0,031  |	0,006   |	0,031
>342695,246  |	5614819,723	|	-0,016  |	0,026   |	0,031
>343584,918  |	5608927,610	|	-0,017  |	0,028   |	0,033
>3.) using towgs-option (Transform-Parameter)
>340408,056  |	5617072,821	|	-0,023  |	-0,334  |	0,334
>342695,237  |	5614820,058	|	-0,007  |	-0,309  |	0,309
>343584,897  |	5608927,933	|	0,004   |	-0,295  |	0,295
>Parameter:
>dX	+590.1181m
>dY	+99.6226 m
>dZ	+340.1890 m
>rX	+1.185095"
>rY	-1.334952"
>rZ	-2.904521"
>dm = 1.00001651559
>Accuracy:
>1.)  ~ 5m
>2.)  ~ 0.033 m
>3.)  ~ 0.3	m	<=== Why so bad ???
>The accurancy by using the towgs-option is worse then expected, i was
>expecting ~ 0.02 m. Aspacielly the difference in North
>(-0,334, -0,309, -0,295) is remarkable.
>So maybe an algebraic sign is incorrect or what ever, anybody a suggestion?
>Best regards,
>Greg
WhereGroup GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Gregor Fikoczek
Email: gregor.fikoczek at wheregroup.com
Fon: +49 (0)228 / 90 90 38 - 25
Fax: +49 (0)228 / 90 90 38 - 11
info at wheregroup.com
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
Mit freundlichen Grüßen / Kind regards
Gregor Fikoczek
Siemensstraße 8
53121 Bonn
Germany
Gregor Fikoczek
www.wheregroup.com
Komplementärin:
vertreten durch:
